Re: Mercury 115 plug wires
Yes they do. Sometimes they get moved around, along with the coil primary wires to isolate a bad coil. Be sure you check the primary wiring also, both at the coils and at the switchboxes. They're color coded, and maybe even labeled.
If it's that fuddled up, you better check link n sync, including timing before you start it. Would be a shame to grenade it first time out.
hope it helps
John
