Re: mercury 1150 flywheel bolts thread pattern?
Thread pattern (??), do you mean torquing sequence??
If so, just snug all the bolts down; tighten one bolt then the bolt opposite the one you just tightened. Work around the flywheel until all bolts are tight.
Bolts should be torqued to 25-foot/lbs.
Prior to installation, degrease the bolts and apply one drop of Loctite Red threadlocking compound to each.
BTW these bolts are 5/16"-NF, Grade 8 if I recall.
HTH.........ed
