warnersworld
- Apr 21, 2003
- 1
I have a problem getting the motor to start simply by pumping the primer bulb and cranking.<br />I've had to inject a little gas in each carb and then she starts right up and runs great after that.<br />I've checked the tank vent and it is clear, the fuel pump pumps gas with no problem, and no gas <br />comes out of any carb wether the motor is tilted up or not. A friend told me the other day that he <br />had a Mercury and that they are cold starters and that he had to crank it quite a bit. Does this make<br />sense? If so how long should I have to crank the motor and should I advance the throttle some?<br />Thanks for your help.
