zepplinswt
- Dec 27, 2002
- 9
I just had the powerhead on a 2001 mercury 2-stroke rebuilt due to overheating. OCC out of Washington rebuilt it. Anyways, just got it back two days ago. While running the boat with the mechanic I noticed the motor was sluggish at certain rpm's. The powerhead had about 1.5 hours run time on it he said. The oil mix was 4.5 ounces to every gallon. When running the boat it would sound like it was missing, he called it "double stroking" due to running rich mixture of oil to gas. Running at 3800 rpms then backing off the throttle a little you can hear the engine brdddd-brdddd-brdddd-brdddd quick burst on the pistons, then the noise will stop and it will run fine. While increasing the throttle it would sometimes do this and it would lose power when it does, then moving the throttle a little more and the sound goes away. You can definitely feel and hear it when it happens. I am not sure what to do? I think there is something wrong. Is there? The mechanic says this is normal and will go away when I start running 50:1 mixture. I had him disconnect the oil injector so I don't have to be concerned with that failing me. Will disconnecting this have any adverse effect? I had a temperature gauge and water pressure gauge put in. The temperature on the motor never gets above 100. I am running it in 55 degree lake water? Does the thermostat regulate the amount of water or is it always wide open? I just can't take it back to the mechanic because he is in arroyo city and I am in Austin, Texas. 6 hours apart. This is my first boat and have had it less than 4 months and its been in the shop for 2 of those four months. Any suggestions/comments would be great.
