mercury 125 help plz
qwert9999
hi, i've got a 1999 125 outboard. it sat for about 10 months. it started up fine and sounds good but i could tell the bottom 2 cilinders were not firing. i pulled the carbs off and didn't fine anything wrong. there were nice and clean. but i can tell it only running on two cilinders becase i also pulled the plug wires on the two bottom off the bottom two plugs and there was no change. i'm getting spark to them. but the spark plugs come out clean. i'm lost as what could be the problem. i also pumped the ball when the carbs where apart and gas came out. also the fuel bowls are full of gas. when i spray carb cleaner into the two dead cilinders you can hear them fire. so for some reason i'm not getting fuel to them. plz help. thanks for yor time.
WillyBWright
Re: mercury 125 help plz
Welcome to iboats.<br /><br />Believe it or not, they're not supposed to work at low throttle. They kick in at about 1/4 throttle. They did that to smooth the idle. Unfortunately it has led to vast confusion. :confused: <br /><br />The idle mixture is set so lean that the cylinder will not fire, yet enough gas passes to lubricate the internals. Weird feature that has led to a ton of customer dissatisfaction. :(
qwert9999
thanks, that is what i was thinking after i saw how clean the carbs where. but i wasn't sure. i was going to start looking for a vauuum leaks next. i spent all day on that thing when i could of just made a phone call or posted here. i'm really kicking myself now.<br /><br />thanks again
markfree
i have a 2001 125 it cranks everytime but sometimes when putting it into forward or reverse it dies. if i push the throttle further into forward quickly it runs fine. just one little spot between forward and nuetral that it will die. does anyone have an answer
