islander12
- Apr 26, 2005
- 20
I have a mercury 135 (94) that dies under throttle.<br />History: Accelerated to get boat on a plane, she cut out. tried re-starting, nothing. Eventually towed back to my slip.<br /><br />The starter motor turned over, appeared to be no spark.<br />I replaced the fuel filter, checked plugs, no carbonation, in fact all clean.<br /><br />Started motor, boom she fired. Wasn't happy as it sounded as if she wasn't firing on all cylinders (lay mans interpretation).<br />Had a friend of mine, who runs a marina check it out. He found some bad "grounds" cleaned them and ran the boat. Said it went fine and all was in order.<br /><br />I ran boat and under acceleration she cut out. Limped back to slip low revs, she cut out frequently. Pulled boat.<br /><br />Any ideas on where my problem might lie now? Appreciate any insights, before I go to the next phase.<br /><br />I plan to replace fuel line from tank to motor. Re grease the seal on fuel/water separator. Do i need to check carbs? I believe there are three as it is a six cyl. Can't believe that one would shut down the motor.
