Mercury 135 V6
EMVEE
I bought a new Mercury 135 V6 which is just about run in now (done 8/9 hours but still on 50:1 mix fuel). Runs great no problems at all - until we try to pull a skier. The engine just dies at 2000 revs. this remains the case (even without skier) until we swap to the spare fuel tank - and the engine runs fine again.<br /><br />We thought originally that it was a fuel tank/line blockage as swapping the lines seemed to solve the problem.. until the problem occured on the spare tank too.<br /><br />Can anyone throw some light on the matter???<br /><br />Thanks in advance,<br />Mark
Bob_VT
Re: Mercury 135 V6
Fuel Pump. Have someone pump the fuel bulb when you approach 2000 rpm. I suspect that you are not getting enough fuel. This is a down and dirty quick test for the pump.<br /><br />Good luck.
