I just bought a boat and LOVE IT, unfortunately, it has a bit of a problem. Most of the time when I try to go, the engine sputters and dies when I try to run it faster than 1400 rpms. It's like it's choking and can't go any faster without dying.
However, some of the time, I'll start accellerating, and the engine will run PERFECTLY !! I'll be buzzing along at about 35mph across the lake with no problems, no sputters, no hesitation. It just works great.
Then, when I turn off the engine to do some fishing, or trolling with my trolling motor, and start it up again and try to go, I get into the same problem where it won't go over 1400 rpms without just dying. I can have it steady around 1000-1300 rpms and it will run a bit rough, but it will die when I try to accellerate past 1400 rpm.
Then again, when I turn it off for a while, and restart it, it will sometimes work fine and dandy without any sign of problems.
I just can't figure it out. As long as it's not in gear, I can rev the engine and it wont ever sputter, but when it is in gear, I have about a 20 chance of it actually letting me run it over 1400 rpms.
Again, once it gets going, there is no problem at all, it seams like something must not be engaging correctly when I put it into gear most of the time and it just can't handle going over 1400rpm, but it's just unpredictable when it's going to work great, and when its going to choke at 1400 rpm...
As a side note, the hydrolics has a leak somewhere in the system so when it runs low, I cannot lift or lower the engine. Not sure how hard that is to repair. Could the hydrolics problem be related to the engine trouble ??
Any help anybody could give me with this problem would be GREATLY appreciated.
Thanks a bunch,
Curtis
Thanks a bunch,
Curtis
