Russ Keeler
- Apr 1, 2007
- 5
I have a 1975 1500 mercury outboard previous owner has been working on. There are two check valves thascrew into block, one on top of motor, one at bottom. They are connected by a piece of 1/8 inch hose about 2 feet long.I need to know which valve goes in which hole. The bottom valve has a rubber duck bill allowing air only to travel up towards top of motor. Top valve only has a screen ,allows air to pass either way.Is this correct? Thanks, Russ Keeler
