i have a 1989 Merc 150 XR4.
The input shaft on the lower unit is froze and will not turn. I thought the engine was seized at first because that wouldn't even turn, but, once i dropped the lower unit, it turned freely without the spark plugs. (whew)
So, now my problem is the input shaft on the lower unit. It will not budge one iota. The unit seems to shift OK.
My question is why would this shaft be frozen like that? spun bearing maybe? I noticed it has a special nut below the water pump. If i remove that, will the shaft slide out, or do i have to disassemble every thing? As a retired toolmaker, i don't mind getting into mechanical repairs.
Any help would be greatly appreciated.
