Mercury 200 problem.
Cliff1234
So I have a 1988 mercury 2.4l 200 I blew up. I put a 1996 2.5 pro max powerhead in its place on top of the 88 midsection. Runs great but I can’t keep it cool nor get any water pressure on plane. 1-3 lb at idol 3-5 at wot. Motor is in water good while on plane . tell tell always got water coming out. New plumbing done to motor t-stats are in place poppet vaulted is in all factory plumed. New water pump and housing.
to me that’s no expert it seems the water is dumping into the exhaust before supplying the engine. The water has flow off the top of the block at idl but I can easily with very little if any effort with my finger stop it there just no force Please help this has been a tuff one.
Cliff1234
Did you install the 2.5 adapter plate?
Form what I was told it was replaced but what I fear is I have heard that both pieces need to be replaced with a plate from 1992 or newer and only one was if this is even possible . The problem is I do not see a parts number on the parts and I do not know how to identify them the difference that is.
Dukedog
a 2.5 (even tha 225 PM) will run ona 2.4 mid... can get ya part numbers but if ya don't know what ya lookin' at you probably won't know tha difference... if this is tha case ya need ta start completely over with tha adapter plates.. there are several combinations you could possibly have and if they aren't right ya gonna have tha problems ya got... ya need ta find matching plates for a 2.5 to erase any doubt.... ya may hafta buy a mid minus clamp and trim... 2.5 150, 175, 200 will work with tha only difference in size of exhaust openings.. you can run 'it like that with tha metal infused 225 PM powerhead gasket...
Dukedog
a 2.5 (even tha 225 PM) will run ona 2.4 mid... can get ya part numbers but if ya don't know what ya lookin' at you probably won't know tha difference... if this is tha case ya need ta start completely over with tha adapter plates.. there are several combinations you could possibly have and if they aren't right ya gonna have tha problems ya got... ya need ta find matching plates for a 2.5 to erase any doubt.... ya may hafta buy a mid minus clamp and trim... 2.5 150, 175, 200 will work with tha only difference in size of exhaust openings.. you can run 'it like that with tha metal infused 225 PM powerhead gasket... run tha 2.4 200 tuner.. its as good as ya gonna get..
Cliff1234
Ya I was thinking the same thing my self was just hopping for some magic trick that I didn’t know . I found a set bottom and top from a guy they came off of a 95 2.5 I will buy them as a set and install them with the metal infused gasket and go from there. You said that I use that 225 gasket not the 200 or is there no difference?
Dukedog
thinkin' PM has a slightly bigger exhaust openin' vs. production blocks best i remember.. don't hold me to that though.. any 2.5 "high performance" gasket will work though..
Cliff1234
Ok , so I found two sets matching. One set is a 99 2.5 135 optimax serial # og805157
The other is a 2000 2.5 135 opti serial # ot147104
my question is will these part work for what I need to do?
Dukedog
sorry, can't answer that.. i've not fooled with tha opti parts enough ta know.. but i'm pretty sure there is gonna be a difference???..
maybe someone thats "in tha business" can answer that...
Cliff1234
Yes I agree I wouldn’t think they would be the sam either. I have called all the shops around here everyone scared to say yes or no. Do you have a contact I could reach out to? Or some one I could tag in pot maybe ?
Dukedog
2.5 opti? (screamandfly.com)
picture "rock" posted is a modified one piece plate.. tha one your lookin' at should be a two piece.. it will have two external discharge holes.. a large one and a small one.. you will need ta plug tha large one.. its for compressor coolin'....
Cliff1234
Ok I think I understand so I’m on the same page . The 2 piece would work fine with my factory tuner?and I will have to plug the large hole. That all
Cliff1234
I replied to his post form you link you sent. I will give him some time to reply they may be gone but I believe that exactly what I need
