mercury 200hp running on 2 cylindars only
mmaxey
Hi, i have a 1978 mercury 200hp, it was just rebuilt before i bought the boat. <br />Here is what i have checked.<br />Stator, trigger coils, main coils, timing adjustment, carbs, compression.<br /><br />it only runs on #1 and #4 cylindars out of 6<br /><br />new reeds were just installed.<br />the carbs were just rebuilt at the marina.<br />it has new cdi ignition boxes. wiring is correct.<br /><br />spark is fantastic at all cylindars, jumps at least and inch, and is bright blue.<br /><br />i tried spraying gas into the cabs of the cylindars that were not firing and it did nothing.<br /><br />am at a loss of what can cause this since the spark, fuel and compression seem to check ok. 125lbs/cylindar when warm.<br /><br />have never had this much trouble fixing any motor before. please help if you can thanks
JB
Re: mercury 200hp running on 2 cylindars only
Why post this in a non-repair forum, MM??<br /><br />Moving to Merc Troubles.
DHPMARINE
MM Motor ran okay when you got it?No work performed since?You say wiring is OK.Do the wires with the yellow band go to the same switchbox?<br />Also fuel sample good?<br />DHP
2springers26
Make sure the pistons are in correct... starboard & port.... it will not run if they are missmatched.... since it was just rebuilt!!!
mmaxey
yeah i know i didnt realize i was in the wrong catagory sorry.<br /><br />no the motor hasnt ran correctly since it has been rebuilt.<br /><br />i was thinking the same thing on the pistons so i will dissaseble it and check it this weekend.<br /><br />yes the blue/yel and red/yel wires are on the same switchbox.
mmaxey
i havent taken a fuel sample, but i just filled it up, it was empty when i got it.<br /><br />also i ran it off a mixed fuel gas can i had in the garage and it didnt change anything.
mmaxey
one question i did have is the seals in the crankcase, if they are bad could it cause this??
2springers26
bad seals... i don't think so.. seals would only effect #1 & 6.. because of the sealing rings.... just pull the heads to verify piston location... port & star are marked with a up & a p or s!!!
mmaxey
Ok thanks for the help fellas. I will check the pistons this weekend. I will let you know next week if thats it or not, but i bet thats it.<br />thanks again
mmaxey
yup thats it, running fine now. thanks for the help i appreciate it.
