Mercury 35hp
HTG
Hello I was out recently and all of a sudden I went to start the engine again and it kind of half way and then the I tried it again and it made no noise at all and now I can't get it to turn over at all. I know its not the choke plunger, water pump or battery. Does anyone know what this could be? I would like to fix it myself if I can. Is it the starter or is there another name for it?
tashasdaddy
Re: Mercury 35hp
are you saying the motor is siezed or the starter won't work? can you turn it over with a rope?
HTG
Re: Mercury 35hp
Then engine doesn't make any noise at all when i try to turn it over. I didn't try turning it over with a rope. I will try that. Does this at all sound like it could be a plug?
HTG
Re: Mercury 35hp
Hello,
I went out and tried to start it with the rope. I couldn't get the full pull, It felt like it was seized up. Anyone know what this means?
HTG
Re: Mercury 35hp
Does anyone know how long it generally takes to replace the starter kit? Is it very difficult to do?
Harker
Re: Mercury 35hp
Take out your spark plugs and see if it turns over with the starter..or rope. Is the battery charged? Check the fuse also.
HTG
Re: Mercury 35hp
Where is the fuse located? I will try everything thanks!
Harker
Re: Mercury 35hp
Look at the block where all the wires go.
HTG
Re: Mercury 35hp
Well I tried everything. I noticed when the spark plugs were out I was able to pull a full pull, but I could not when the spark plugs were in. Does anyone know what this could be or what parts I will have to replace?
