Re: mercury 40hp won't start
I tried to check my timing using Clams Canino's post on timing and sync,but the timing marks on my flywheel don't line up with my pointer. They are off about 90 degrees. When the no. 1 cylinder is at tdc shouldn't the pointer be at 0 on the flywheel? With the no. 1 cylinder at tdc I removed the flywheel from the hub and tried to set it at 0 with the pointer,but it wouldn't line up. With the marks set as close as I could get them to the pointer I started the engine but it wouldn't run very well.<br />I put my own marks on the flywheel and the approximate settings I got were at idle 11 btdc,at the first throttle pickup 17 btdc, and at wot 34 btdc.<br />How could the marks on the flywheel be off so much? I don't want to adjust anything yet. Thanks
