I have a merc, 50 hp, thunderbolt, 1982 4 cyl. engine that was run into a sand bank. I changed the water pump immediately afterwards. Now when you run the motor with muffins or in a bucket, the water flow through the pee hole normally, but gets excessivly hot within a few minutes. It eventually turns to steam. Does this indicate exhaust getting into the cooling system. A gasket, cracked cylinder, partially plugged coolant path? Any info would be very helpful.<br /><br />regards,
