mercury 50 outboard turns over only sporadically
Hi,
<br />I've got a 9-year old Mercury 50 HP on a pontoon boat, and this summer it's only been starting sporadically. For instance yesterday, I went to start her up, turned over for about 5 seconds and didn't catch, and the next time I turn the key to start, nothing happened. Waited 5 minutes and got it to start. Today I go out, turn the key to start and nothing happens. Not a peep. Try again and again and it doesn't turn over. The battery shows at least 10 volts, the engine lowers and raises.... <br /><br />The marina just installed a new battery on Friday because they thought that was the problem.<br /><br /><br />So I took a proper multi-meter out to the boat to check on what you said. Here is what I found:<br /><br />Reads about 12 volts (it's analog) when I test the terminals on the battery. When I turn the key to Start and check the battery, the voltage does not change at all.<br /><br />When I turn the key all I hear is a quiet, single click coming from the engine.<br />
<br />thanks<br /><br /><br />Chucky
Hi,
