Mercury 50hp 1983 timing issue.
INDYCAVER1
Hi I have been dealing with issues on my motor for a while and decided to rebuild carbs. I put it back together and was trying to link and sync it but I am having trouble with the timing. Does a normal inductive timing light work on these old 2 strokes. I had it running and was trying to see the Max timing advance,. But even at idle the timing marks are about 1/4 of the way around the flywheel when the strobe goes off from the timing pointer. Is my timing off that far or is my timing light no compatable with a 2 strokes engine? I started this whole project because I can idle fine, but can't reach over 3000 rpms at wot. Would the timing be the reason, and how do I fix it any advice would be greatly appreciated
INDYCAVER1
Ok here is an update. I downloaded an cdi troubleshooting guide and read up how start sorting out my problems. I pulled the #1 plug and manually spun the motor over with the plug grounded out and didn't see any spark. Same thing on #2. I hooked up the hose and started to motor. Shut it down and unnhooked the #1 plug wire and restarted with no changed and did the same thing with #2. No change in rpms or any thing. I can put 1 and 2 plug wires on and disconnect #3 or #4 wire and it won't run. It acts like it wants to but 1 cyl isn't enough to keep it running. If I hook the timing light to #1 or #2 it flashes but not consistently like if I put the timing light on #3 or #4. The trouble shooting guide said if you are misfiring or nonspark on #1&#2 or #3&#4 to swap the trigger wires on switch box. It says if the problem moves to the opposite 2 cylinders it's most likely stator is bad. If the same 2 cylinders are still not sparking it is bad switch box. I feel like this is my issue. When I swapped the wires #1 and #2 still no fire. I even took the coils from #1 and #2 and switched them To #3 and #4 and they were firing just fine so coils are definitely good. I guess I will try a switch box see if that takes care of it.
jimmbo
Move the wires from the Switchbox to the coils to see if the problem moves
INDYCAVER1
Replaced switch box and now I have spark in all 4 cyl. Hopefully take it out in the morning and see if I have full power again
