PepinMatt01
- May 29, 2010
- 4
My 1983 50hp Mercury, starts and runs at trolling speed fine. When i go to full throttle it bogs at about half throttle. When i hit the choke it will cut out more but not stall. I replaced the fuel lines from tank to carbs. Installed new plugs. Compression is 110-120 on all cyls. Replaced one coil and plug wire. Didnt help. Took it to Dealer. They tested it and said the Stator was bad. I replaced with a CDI. Still have same symptoms. Today i tested the Trigger and rectifier. They tested ok. I'm using Seloc manual for specs and guidance, but at this point i need some help. Thanks
