Eng starts good plenty of power usualy .but some times you mite be running full tilt for a while and then all of a sudden a steady beep will go off or you would be running open up and then go to idel for a while and then the steady beep goes off loss of power or dies out.Some times if the motor dont start the main wire hook up connection on the starter side is not as tight as it should be and some times you can touch it and then it will start and runs good but once it is running good and the steady beep goes off it don,t help to touch the cable at all.
