Re: mercury 5hp 1991
The internal tank may be dry but that doesn't mean there wasn't still fuel and oil in the engine.<br />If there was,after 12 years, the oil is tar and the gas is pure varnish. You need to clean the carbs and maybe mix some stabilizer in your gas to help clean out varnish deposits. After 12 years,it's very possible your fuel system is plugged,something could be frozen, fuel pump diaphram could be rotten, etc.......<br /><br />After you try to start it, pull your plugs and make sure you are getting fuel into the cylinders.If they are dry,it's time to start looking.<br /><br />tom
