Re: Mercury 60 HP 4 Stroke Regulator/rectifier
I have a pontoon which makes it a little easier but I used that plastic wire loom. You can possibly follow the other wires not sure what kind of boat you have. Mine is all wired now, just finish, and tach zeroed out when I turned on the ignition, that's a good sign. I did not start it yet because it's sitting on dry land and ran out of time to connect water to it.
Good luck with yours.
