scottwoodward
- May 27, 2020
- 78
Model year 1970 (serial 2804270)
Before replacing fuel pump gaskets, carburetor gaskets, fuel lines and generally cleaning up the fuel system, I could at least get the engine to turn over and run for a short period. But after doing all these things, and replacing the timing belt, I cannot get the engine to start. I've got spark and the alignment of the pulley and marks on the flywheel are correct (arrow on pulley and three notches on flywheel; my model is the one with the incorrect sticker on the top cowling, but when the cowling is on, it lines up correctly). Spot checking TDC with #1 also shows alignment (but only eye-balled, not with a timing light). I'm getting fuel into the carbs, but it will not start. The timing belt slipped twice, which I thought was the problem, but it has stayed in the correct position the last three attempts at starting the engine. I don't know where to go next -- when I try to crank the engine, it let's out what sounds like a backfire as you can sort of hear in this video (https://drive.google.com/file/d/1ZY4dmBhjyp1aEy82QT1whRvXlH9pHxWw/view?usp=sharing). I don't know if I've got a spark/timing issue or a fuel issue.
