Re: Mercury 7.5hp 1986 long shaft sailpower requires high revs before forward wi
timsie,While your forward operation problem may still be a spun prop,I'm leaning more toward a problem in your shift linkage since it seems to engage with a "clunk."You'll have to see if you can override the linkage from shift handle straight to the shift shaft.The shift shaft has gear attached to the end that is actuated in a turning motion by a sector(worm)gear on the end of the shift handle shaft.These gears may be worn.If it still won't engage you may have a problem in the lower unit itself.
