Mercury 70 (1979)
rossclabburn
I need help..... I have a 1979 Mercury 70 horsepower and the problem is a cannot tilt the engine from the down position to upright so that i can tow it.... Can anyone help?????? I have tried for hours and cannot do it... :confused:
Spidybot
Re: Mercury 70 (1979)
Do you have power trim?<br /><br />If no, the trim/tilt should move absolutely free and easy, just affected by the weight of the motor.<br /><br />If you do have powertrim, the hydraulics are meant to keep it in position and you can pull and kick all you like - it will stay there!
rossclabburn
No i dont have a power trim........ but does the gear have to be in neutral in order for the engine to lift up??????
Spidybot
Without powertrim there is a lock to prevent the prop from being drawn out of the water when in reverse. This lock grabs the tilt-pin when in neutral or reverse.<br /><br />Put the remote or gear lever in forward and it should be free to tilt.
Ken G
With the motor in Forward if it still will not tilt you must manually lift the reverse tilt locks. They latch onto the tilt pin and sometimes do not raise if the little spring is missing. I learned this last weekend after hitting a log and apparently losing the spring in the process.
