Mercury 75HP will not idle or take fuel
boutime
Hi everyone.<br /><br />I have a 1987 16 foot Sea Lion with a 75 HP Mercury 3 cylinder outboard motor. I cannot get it to idle unless I keep pushing in the key to activate the choke. Also when trying to increase revs it will die. I removed the fuel tank and flushed it along with the fuel lines, cleaned the plugs and fuel filter, even replaced the primer bulb. Bulb will get hard when pumping, but will lose it shortly after. Tried squeezing bulb with motor running-no help still dies. Serial # on motor is #OC260749 been told the motor is the same year as the boat, but dont know for sure. Any help would be greatly appreciated. <br /><br />Thanks, PdA slitheryspace@msn.com
greasemonkeyozi
Re: Mercury 75HP will not idle or take fuel
Wouldnt hurt to replace your fuel pump diaphram either. An easy $4.00 job your self.
boutime
Thanks, I will be working on it this weekend and I will get back with the results.<br /><br />Thanks again for all the help slitheryspace@yahoo.com
