Mercury 850 Engine Rebuild Planning Stages
wguttrid
Hey guys planning on rebuilding engine during the off season and just researching the cheapest parts and kits and was wondering what the engine guys here would recommended I clean up and replace.
The engine I have is a Merc 850, compression is reading 140 +/-3 on all cylinders, have a newer lower unit installed on it that holds good pressure for 35 minutes.
What are some thoughts on items I should look at during the off season. Not looking at spending a fortune on it but at the same time not looking to cheap out.
wguttrid
Re: Mercury 850 Engine Rebuild Planning Stages
Also it is either a 73-74 and is not in bad shape but it is showing its age.
buddyp
Why rebuild it does it run ok...comp looks good ...did you do a leak down to see how it is sealing?
Faztbullet
If your going to the trouble of tearing it down, do the full rebuild. I have not seen but several inlines that did not need boring do to side thrust wear around ports. If it was mine I would:
1) bore .015 or .020
2) restricter mod
3) replace reed blocks with late models (less wear on labryth seals)
4) full carb,fuel pump and hose replacement/repair/rebuild
5) replace/repair any bad wiring internally and check/repair stator
6) full water pump kit and lower unit pressure testing/repair
