outdoorsman37
- May 28, 2010
- 25
Hello, I just was given a Wellcraft 165 Airslot which has a Mercury 850 on it. The lower unit is off and taken apart. Some of the parts are rusted. The powerhead looks clean. I tried to compression test it by hooking up a battery and turinging it over. It tested at 95-100 for all four cylinders. I sprayed some WD40 in the cyclinders and then the compression was around 110 in all cylinders. So, what should I do? Should I keep it and try to fix it up or buy a lower unit or replace the rusted parts or dump the whole engine or sell some of the parts? The controls are all hooked up. They seem to be working fine. The engine turns over fine.
Any help would be greatly appreciated. Did I do the compression right. Could it be higher if I missed a step?
Thanks!
Thanks!
