Re: mercury 9.8 impeller
do you have a manual?<br /><br />i wont even tear into any of my engines with out one.<br /><br />but a tip would be make sure you put the vanes in the right direction, follow the old vains for guidance.<br /><br />while your at it, change the t-stat if your motor is equipped and change lower unit oil. never sieze on the bolts is good since they are under water<br /><br />mike
