Have a 2000 90hp 2 stroke 3cyl that had the same symptoms last year.
Replaced the coils, fuel pump rebuild, spark plugs, cleaned carbs, and replaced the stator (which fixed it for the past 5 months). Compression is 120, 120, 100. A little low on one but runs fine throughout range.
Took the boat out this weekend and had no issues at all running over 6 hours and 30 miles. Come this week, running the boat at 4500 rpm for 15 minutes and the tach started to bounce around then the motor cut out. Started right back up but then wouldn’t go beyond 3k rpm. I cut it back off and 10 mins later it went back up to 4000 for 10 mins to get me back.
almost seems like it’s a limp mode but I know these old engines don’t have that. The block is also not getting very hot making me think it’s not an overheat. My thought is it Hass to be electrical because it only happens once the engine runs for an extended period at higher RPMs. Bouncing tack is also some indication that there’s an electrical issue. Any thoughts about next steps?
