I installed the throttle and shift cables on my motor and the first time I took the boat out with the new cables on, the engine seemed to grind a lot more than it did with the old cables on, before it would ever go in gear forward. However it seemed to go in reverse without grinding at all. Does anyone know the distance the shift cable should be. Or how far you should screw in the "nut". It didn't start in gear so i know i have to be close to where it suppose to be. Any help would be appreciated.
