Hello, I have a 1991, 135 v6 Merc. I got water in my fuel and now I cannot get my engine to run. I have changed my plugs, fuel filter, fuel. I can get the engine to start if I spray starting fluid in the carbs, but not otherwise. The fuel pump is working because fuel makes it all the way to the carbs I disconnected a line at the bottom carb to check this. I was thinking maybe the needles are clogged or something. Is there anyway I can blow compressed air through the fuel line to try to clean out the carbs or anything?
Thanks.
Thanks.
