Motor: 1987 Mercury Classic 50<br />Serial Number: ? (Can't Read)<br /><br />Problem: <br /> Motor will start at with throttle up and not in gear. and then you can back it down and it will have a rough idle. Motor will start up and move along, though really slow and sounds very sluggish and not to full potential. When you have the motor fully trimmed up or down and prime the fuel bulb and solid stream of gas will come straight out of the top carb. like shooting a water gun. Does not appear to be doing it when while running. Top carb. is sucking in air, though the bottom was not. Took them apart and bottom carb. was clogged. Both floats on carbs, respond properly when air pressure was present in fuel line by air compressor. Now the motor runs fine out of water, sounds like a champ; though once a load is present on the prop, it goes back to the same old sluggish it was.<br /> Cannot seem to find a diagram online of the carb. setup for the motor without Serial Number.<br /> Any help or suggestions will be greatly appricated...
