I've heard of it being possible to upgrade or convert a Merc 135HP to a 150HP with a few modifications. Is it possible to convert between a 75, 90, and 115HP with mods? Has anyone done it? I know that the engine specs are identical between the 3.
75HP 90HP 115HP
Max RPM (WOT) 5000-5750 SAME SAME
Cylinders 3 (in-line) SAME SAME
Displacement (CID/cc) 92.96/1526 SAME SAME
Bore & Stroke (in) 3.63 x 3.00 SAME SAME
Bore & Stroke (mm) 92 x 76 SAME SAME
Gear Ratio 2.33:1 SAME 2.07:1
Thanks In Advance!
75HP 90HP 115HP
Thanks In Advance!
