Mabe someone here could bring me up to date on Mercury's ignition system.
I was a master certified ase tec. for years (L1) and Senior product designer later on . I have worked with processor and non processor based systems. Many sensors/switches optical, magnetic, hall, ect... are used with the above systems. Most used and reliable of all are the powered magnetic type. When rotating an old (1974-up) electronic distributator you will feel magnetic detents throughout the rotation corosponding to the amount of cylinders. When you rotate a mercury distribuator there are close to 50+ detents, 3 windows, 6 lines. Has anyone ever scoped the return wire before. Dual signal mabe?? 90 small sign waves, 3 on and off
