Hello,
I have a 1998 mercury 115hp elpto. The motor runs great. I am having trouble getting it to shift into reverse on the water under load. The outboard shifts fine when outside of the water on muffs.
Some background info so this all happened after I got a spun hub. I was out in the water and shifted into reverse and it seems that the prop nut came loose and resulted in a spun hub. Replaced the hub and then realized the issue with the reverse.
Things I have tried. I thought maybe the cables needed to be adjusted. So I tried disconnecting the shift cable at the motor, and shift it manually in the water and it still did not properly engage. When shifted into reverse in water it makes a noise like (my theory) if the clutch is trying to latch/engage or just jumping out of gear like a rapid muffled clank clank clank. So something has to be adjusted.
Any help/ideas is much appreciated.
