Mercury Hub kit for a Johnson prop
skidog519
I have a 3 blade Viper stainless steel propeller part # 0763918 14 ? x 19 RH I previously usaed on a Johnson outboard.
I have since switched motors and I now have a 2000 Mercury 225 EFI. Do they make a mercury hub kit to fit that propeller? I know you can go the other way from a mercury prop to a Johnson hub but I am not having any luck finding anything going from a Johnson prop to a mercury hub as the design is slightly diffeent. Any help would be appreciated or any other places to check. Thanks
Re: Mercury Hub kit for a Johnson prop
Ayuh,... It should fit, As Is...
skidog519
The Johnson prop is hub less and all the Mercury hub I have tired so far dont fit as it is a slighty different design
