Hi i am newbie to this forum. I am hoping every one can give me so advise.
1986 L6 90hp merc. i got it used but has sat for long time. i have put many new parts on it and now it finally runs, well almost
carbs were cleaned and rebuilt, new switch boxes, stator, fuel pump, fuel lines, plugs, timeing and carbs were syned.
my problem is she idles good, put it in gear idle is about 700ish give it throttle it will rev to 1000 any more she dies. i can hit the enricher and give it more fuel and revs to 1800 in gear, then takes off under power and runs awesome. i have a dead spot between 1000-1800. In neutral the idle is around 1300rpm is that noraml to have such a big drop from neutral to in foward?
i have tried the idle mixture from half turn out to 3 turns out, she likes it best around 2.25 out. but no major difference. i do notic at WO with mixture screws out past 2.25 i loose the sucking sound from the carbs. no diffence in rpm, just noise.
Any tuning tips or if any one has had this problem please help, i have so much time and money in it, i cant stop now. Thanks
