mercury lower unit
rlouis5
I have a 1984 Mercury outboard motor that has most of the skeg broken off and the gears inside the lower unit are exposed . It still shifts and it will still run but will not hold oil in lower unit..(it is a very large hole ). I have been looking for a replacement lower unit but they are very expensive. Can I but only the housing for this lower unit (without gears and bearings) or will any other lower units fit this motor?
thank you
Robert Molet
Re: mercury lower unit
thank you
Robert Molet
Ayuh,... Welcome Aboard,...
Ya might get an answer to yer question, if ya noted WHAT motor ya got....
Mercury built motors from a horse or two, to a couple hundred horses that year ya know...
rlouis5
Of course you are correct. This motor is a 1984 150 hp Black Max motor .. I also have a 1992 150hp 2.0 liter black max on a 1996 procraft boat and could use the motor for parts but the 1984 150 seems to run perfectly on ear muffs.( I have never had it in the water. it was like this when I purchased it) so I hate to use it only for parts and would like to repair this motor.
sorry for the inadequate earlier post
Robert
Faztbullet
Yes you can buy a housing and transfer the internals, but you will have to re-shim the backlash and pinion height.
rlouis5
This is a 1984 Mercury 150 hp Black Max motor serial # 5072422. The gears in the lower unit is fine but the housing is junk. Will a 1992 150 Black Max lower unit ( 2.0 liter ) fit this motor? Where can I purchase only a lower unit for this motor? thank you in advance
Robert
1nebel0
Lower units are a dime a dozen on Ebay....be careful on buying someone's junk...$300-$500 all day long
Faztbullet
Before I spent $500 on used one I would add a few to it and get a NEW one.
