Mercury/Mariner 50hp Carbs
Segal_ZA
Hey All,
Im looking for some assistance.
I need a set of Carbs for my Mariner 50hp 2005 model. The parts show as a WME-63
I can get hold of a set of 1997 carbs that read WME-26
From what I can see and make out from the parts diagram is that its just the jets that are different in size.
Can anyone confirm from experience if this is the case.
From the outside the carbs look identical but the part numbers are VERY different
Thanks
Dani
What is wrong with your carburetors ?----Not much can go wrong with them and usually they can be refurbished to work like new.
Segal_ZA
The motor sank, they ran oil through the block and it turns well and still has good compression but the carbs were not touched. Everything is stuck solid and in a bad way. I can get a used set of carbs way cheaper. The guy who is selling them upgraded his 50hp carbs to 60hp carbs so the set are in perfect condition and cheap.
