If this were a '67 VW Beetle, I could figure it out, but I'm new to outboards.<br />I'm replacing the fuel lines on a '57/'58 Mercury Mark 10 but can't find the brass fittings for the 1/4" hose. <br />I also can't find a female tank-side fuel adaptor that plugs into the male end on the motor. <br />So, is there a problem with replacing the old adaptor with a more contemporary 3/8" adaptor and then stepping down to say a 5/16" line to get into the fuel pump? How about also using 5/16" line between the pump and the carb?<br />I've also noticed that some folks recommend sticking with the originally recommended Lubriplate 105 in the lower unit, but others swear that hypoid 90 wt. works just as well. Which is right? Sorry if that's already been beaten to death.<br />The motor came with Champion J6C spark plugs though J7J was originally recommended. Are they interchangeable?<br />And one last question, does anyone have an opinion on this motor? Any peculiarities? I notice that Mercury only made it for two years.<br /><br />Thanks.<br /><br />Jack Rose
