Mercury model 4
bstump
I have this sweet running 4hp outboard from 1980. I cannot seem to find the right prop. I'very bought 2 different ones... part #48-63494A10. The other one? Splines are too big won't engage the spline on the motor. Any ideas? I've spent $170 on props! Can the lower gear assembly be swapped out for another?
bstump
Here is a picture
bstump
If I cannot find the correct prop, can I replace the prop shaft to accommodate a known prop? Or is it not that simple and I would need a new lower section?
STOP-----Clearly you or someone ordered the wrong prop.----If it was the dealer get a refund / exchange.---So check your serial number.----Is this a 2 cylinder motor , yes or no ? -Post pictures of powerhead.---Post pictures of the lower unit.
bstump
Here are the pictures for you to help. it is a 2 cylinder. Believe me, the dealer ordered the wrong prop twice!
I believe that motor is referred to as a " gnat " on the parts website.
bstump
GNAT. You are correct. The prop is discontinued. Anyone know of anyone who stocks old hard to find parts?
bstump
No luck anywhere! The part numbers that say they fit, do not fit.
