mercury not firing on two cylinders but....
brian wig
when i remove the two plugs it is not firing on and start it on one then let it run a minute and put the other two plugs in it will run and fire fine any ideas on what to check ? power pack does have a naked wire that isnt attached to anything best i can tell been trying to get this motor going since fathers day for fathers day lol
1987 mercury 70 hp 3 cylinder
brian wig
Re: mercury not firing on two cylinders but....
any ideas on this please the bottom right wire is naked and frayed and not attached to anything could this be the issue .
gbrowne9
your switch box { power pack} has probably pack it in.when you get a new one make sure all your grounds are good.
