Mercury online 6 distributor swap
Captain Nino
I have a working distributor that came off of a 1965 900 90hp. I want to put it on a 1971 115. Both are inline 6s. Will it swap?
GA_Boater
Look up the parts diagrams for both motors and compare part numbers, including supersessions.
matt167
it's a distributor, so couldn't you just run the leads in the correct order?
As I recall, the distributor advance is linked externally. one person could modify a Chevy/ Mercruiser 165 6cyl distributor head to go on the outboard shaft/ mount and then use a pertronix kit or the like to get a reliable/ servicable battery style ignition.
the 1965 points are NLA last I knew. Carbs can be rebuilt but without reliable ignition you can be stranded
GA_Boater
Might as well buy a brand new motor for what that would cost to fab up as a one-off.
merc850
Aren't those 2 different types of ignitions? One is dual point/coils and the other is Thunderbolt CDI which uses a trigger device instead of points. Even the mounting systems are different, what's wrong with the 115 ignition?
jimmbo
You are correct, the 1965 engine has a Battery Ignition using points and a Coil, while the 71 uses a Battery breakerless CD system.
