eod-weissman
- Aug 6, 2002
- 1
I have a set of Optimax 150's on a Military Zodiac V-Lift RHIB and one is having troubles. The exact nomenclature from the engine is A 2001 Mercury Optimax 150. Model 150CXL OP serial OT393416. As soon as you start the engine it will run, sputter and die. If you put it in Neutral at a higher RPM (around 1000 +) it will keep running but will be rough and somewhat jerks. Anything lower and it runs exceptionally rough and will eventually die. The higher the RPM the better it runs. When running the boat, the good engine at full power/throttle (a bit above 5200 RPM) the other engine in the same time full power/throttle (only 2200 to 2500 RPM) is jerky and lacks any power it had. I have checked the plugs and they seem fine with the exception of #3 & #4 which seems to have more oil on them then the others. I have also changed out all the fuel/water seperator filters. The boat hadn't been run for about 2 months but before that time it ran fine. The nearest Merc dealer here in Japan is about 4 hours away and there is a slight language barrier between us. So if ANYONE can lend me a hand it would be greatly appreciated. Thanks
