bigheaded5
- Apr 22, 2012
- 153
I recently bought a project boat and it has a mercury with merc controls on it. Its a 1980 80hp. Im used to Evenrude controls so....2 questions
1- there is a separate ON/OFF switch mounted on the boat....is this standard on merc controls or is it a Jury rig of the prev owner (i would like to get rid of it if it is)
2- there is a separate RUN/OFF toggle on the controls itself.... Im assuming thats for a lanyard? When its in RUN, the toggle is up under a cover so you cant shut it off without a screw driver to pull it down with....
on a side note.... 5 year old fuel in the tank AND hose (WTF) compression #1 150psi, #2 145psi, #3 145psi, #4 150psi.... BUT its not pumping water....replacing the pump in the AM....where the heck are the stats on this motor! Mercury stuffed so much into such a small spot.
