Mercury outboard motor won't stay in gear.
Yepblaze
Re: Mercury outboard motor won't stay in gear.
Check to make sure the actuating cable is moving the parts on the motor the full amount.<br /><br /> If that checks out OK disassemble foot section and look for loose, worn, or broken components.
RICKRICK1
Ensign
ljonkers<br /><br />You did not say wether this is a known problem or has just started. Are you sure it is coming out of gear or a spun prop hub? Additional information would help. As suggested above check you shift cables and linkages.
ljonkers
The problem with the Mercury not staying in gear is a newly developed problem. Thanks for the help..
rons boat
Suggest as first step that you temporarly disconnect the shift cable at the motor. You need a buddy for proper operation.
mellowyellow
Ron has the correct starting point... disconnect<br />cable and see if you can shift motor manually.<br />if it works, time for a new cable, if problem<br />persists, time to tear apart lower unit and<br />inspect clutch dog.<br />good luck,<br />M.Y.
