mercury prop size
tengals123
Master Chief Petty Officer
anyone know the approx right size for a 69 merc 100 outboard. thanks
Laddies
Banned
Re: mercury prop size
It depends on the size of your boat and hull design
walleyehed
As said above, boat design and how you intend to use it is important, and so is using a prop that puts you at the top-end of your Max recommended RPM range, regardless of use. whether we need a bow-lifter, or a stern-lifter depends on your boat.
srq_fl
walleyehed:<br /><br />What are the characterstics of a prop designed for bow-lifter versus a stern-lifter?
walleyehed
Bow-lifters tend to have more "rake" (blades angle more aft) and significant cup around the tip. A stern lifter has less rake (blades are closer to 90 degs to the hub, and are cupped at the trailing edge only, if cupped.<br />The bow-lifter in the right application allows more bite at higher trim levels to lift bow and decrease wetted surface area, increasing speed.<br />Some boats don't react well to bow-lifters, and tend to porpoise, this is where a more standard stern-lifting type prop does better.<br />Most high performance Bassboats use bow-lifters, and most deep-V's using higher power outboards run best with a prop that is in-between, and a cruiser, or heavier deep-V (slower) will use a stern-lifter.<br />I have an 18ft alum Deep-V with a 200 that runs real good with the "In-between" props with less aggresive rake, but reacts good to moderate cupping. If I mount up a high-rake bow-lifter, it won't hold the bow up as much due to hull design, and I can't utilize the props capabilities, therefore losing some efficiency.
tengals123
ive got quite a deep v hull, i think im going to just go for a 13x19, that's what's on it now anyway and sounds ok.
