mercury Quickleen
Johnson110
I have been using mercury quickleen they say 1oz for 5 gallons of gas. I use a 6 gallon tanks and a 3 gallon tank. What I have been doing is using the 3 gallon tank and adding1oz of quickleen. Is this safe to do I would rather run 3 gallons with cleaner being on the rich side than adding extra cleaner to the 6 gallons? I like to keep both tanks full, I understand this stuff is good for the carbon build up in the engine.
dingbat
The 3 gallon can will return a 50.13:1 ratio
The 5 gallon can will return a 50.08:1 ratio
Both are well within the allowable margin of error
No need to run it every tank full. I used to run a cleaner through mine once a year for good luck. Have since starting using a 2 stroke with carbon guard in the formulation. Run nothing but gas and oil ever since
