Mercury Remote Control on 1988 Sylvan
Rivergator
I need to remove the remote control which is mounted starboard on the side panel of my boat, because there are some issues with the panel I need to address. Can anybody help, because I am stuck for sure. I am unable to remove the whole panel with the remote on it. Also can anybody tell me the model number of this unit in case I need some parts. (see pictures)
Rivergator
Alright. I guess nobody knows more about it than I do and can give some advise. In the meantime I found the answers I was looking for and the problem has been resolved.
nola mike
For those of you still in suspense, there's likely an Allen screw on the bottom/underneath the handle...
jbcurt00
Thanks for being helpful and posting how you resolved the dilemma.
Very helpful indeed....
Thanks @nola mike for lending a helping hand to those that follow.
Rivergator
I am very sorry. I didn't think anybody was interested. Of course I want to share what I did. First of all my unit does NOT have the Allen set screw on the bottom of the handle as Nola Mike mentioned. After googling my butt off to see if I could find a youtube clip dealing with the removal, with no success, I came across a diagram of a unit close enough but having the same parts as mine that needed to be removed in order to get the handle and front bezel off of the side panel. I found out the hard way by destroying the throttle button, thinking it would pop right off like it's been said it should, but it didn't. Instead it broke. However good news is there are still plenty available for around 4 bucks, so no harm done, thank God. I got 2 on order (1 spare) right now see #5 on diagram. Now I could look inside and see the nut (#6 on diagram) that needed to be undone to remove the handle. A 17 mm deep socket took care of that and after that everything came apart just smoothly and without any problems. Now I just had to undo the bolts holding the bezel and the control box in place and I could remove the side panel without any further problems. Btw., after I removed the control box it had a beautiful part number on it. This is the unit that is in my 1988 Sylvan bow rider for those who like to know. Mercury #858690A3
alldodge
Sorry didn't notice your post. How you get the button out (without breaking) is move the handle forward (NOT using throttle only). Once forward the button can be popped out. Same for going back in
