Mercury service manuals
HAS
Can I get some help with the service manual index on the sticky by DON S, FAQ FOR MERCURY OUTBOARDS? I don`t
know how to read it to get the right number for the manuals I need. First is my 1985 50hp. 4cyl. serial no. a131226
model no.1050525 (I have not seen that serial anywhere).The second is a 1975 85hp. 4cyl. 850 serial no.4295510.
I would appreciate help help to get the right numbers.........THANKS A LOT.........HAS
Don S
Re: Mercury service manuals
There are no downloadable OEM service manuals for those engines. However, if you go back to that sticky, there is a link for the index. Just locate your SN range and find the correct manual. Perhaps a trip to ebay will find you the manuals you want.
carholme
The manual you need for A131226 is 90-86135-5 and for 4295510 is 90-86134-4.
When using the Mercruiser chart, you have to identify your s/n in the right hand column against the country your engine was manufactured in:
(U) = UNITED STATES
(A) = AUSTRALIA
(B) = BELGIUM
(C) = CANADA
(I) = INTERNATIONAL
In the case of A131226, you identify the US by the code letter U and your s/n is higher than the s/n listed:
(U) 4576237 and Above
For 4295510, same code U and:
(U) 4112635 and Above
Clear as mud??
http://www.ebay.com/itm/Mercury-45-50-60-70-HP-Outboard-Service-Repair-Manual-/150676155090
http://www.ebay.ca/itm/ws/eBayISAPI.dll?ViewItem&item=140452275932&clk_rvr_id=316444471262
Gerry
mnRIVERrat
I did actually stumble onto a place to download the manuals for what you are looking for. It's not free, they are 8 or 9 bucks. But I just downloaded recently the 570 some page manual for my 74 65 horse, which is the same for your 85, and they are VERY complete manuals. better than clymers or seloc. Let me know if you need the site.
HAS
I say THANK YOU to everyone for the fast response on Mercury manuals. RIVERrat can you put up that website address I would
like to look at it, and there may be others on this forum that need a manual.........THANKS .................HAS:)
mnRIVERrat
recrepairinfo.com
not sure if these are "oem" manuals as they cover more than one engine but each engine style has its own part in the manual. very informational. just tore down my motor completely with the help of these also able to put it back together
HAS
RIVERrat
MANY THANKS I`LL CHECK IT OUT ............HAS
Texasmark
Seloc is an online manual provider. I have an OEM Merc and a Seloc download (cost money for their service....nothing is free) but the manuals have lots of pictures and lots of verbiage that the OEM manual doesn't have. Definitely worth the small charge. Possibly they have one for your engine.
Mark
